I just put together a cheap rig (its been awhile since ive built one)
Everything went together fine, Booted the fiirst try, and was about to install windows when the CD drive would not read, oh...duh i put the floppy drive plug in instead of the IDE, unplugged the computer and fixed that. Went to turn it back and had no video at all.
CD drive spins up, hard drive spins up everythinng works as normal but no splash screen, bios screen, just black. I checked everything, VGA cable, monitor, MB connections and everything appears to be ok, any clues as to what could have happened between the time of me just swapping out a cable? It ran about 3 mins before i unplugged it to swap out that cable.
