Ok, so after seeing one of the guys here IBM NetVista case that they got off of ebay, i fell in love with it, and decided that it would make a good low end workstation for my work. Well anyways after pricing out the stuff and what not i got thinking about it, and thought wow this would be a sweet as case for a Pentium D setup. (yes that was one long run on sentance).
Anyways the internals of the case are really small! From what i can tell they are about 9.7ish x 8.3ish. As you will see in the pics below the reason the horizontal is so small is because of the HDD cage and the optical cage. I have been looking it over, and i could cut out enough of the HDD cage to fit the larger mobo in and then just get a notebook HDD to replace the full size HDD.
Anyways here is what i am proposing spec wise:
Asus P5RD2-VM 9.6" x 8.6" ** UPDATED MOBO **
Intel Pentium D 805
1 GH Coresair ValueSelect
Shuttle Silent X PC50 SFX 300watt PSU
Zalman CNPS7700-CU CPU Cooler
Alright, and now for the pictures of the case itself:
Intel Pentium D 805
