Recently, my Inspiron 6000d started having issues and would BSOD before finishing loading Windows. I don't happen to have the error code anymore, since it didn't seem to be very specific, but when I looked it up, one or two sites mentioned something about a driver issue relating to the hard drive, or something along those lines. I did a repair of the Windows install just to see if it would fix the problem before resorting to a complete reformat, and it seems to have worked such that Windows actually loads up. But, I noticed that it was loading much slower than usual, so I did a quick test and came up with this:
The drive itself is a 60GB 5400rpm PATA drive. The drive temperature is probably up because it just "installed" (i.e. repaired) Windows maybe 5 minutes prior to testing. Also, one thing to note is that on a couple occasions, a window popped up (from centrino hardware control) that mentioned something about some SMART problem, though I was not using the computer at the moment and the window would go away relatively quickly, so I don't know what exactly it said. I did a couple tests and the drive seems to indicate that it working normally and the drive has no bad sectors. I don't think fragmentation would cause anything this bad, and Windows indicates that the drive does not need to be defragged.
I was just wondering if anyone else had a better idea of what the problem is, whether the drive itself is going bad or if there is just a bad/missing driver for the drive or something else I'm unaware of.
