Help with 3 dead Hitachi drives
dmcmillen
I had a Corsair 1000w power supply go bad and left me with 3 dead drives, (1) 3TB HGTS HDS723030ALA640, and (2) 2TB HGTS HDS723020ALA640 (as well as a DVD drive). By dead, I mean they won't spin up anywhere. I have replaced the power supply and drives and recovered all the critical data that was being backed up to an external drive. Unfortunately, I had 30GB of data that was backed up on all three of the dead drives. Interestingly, the 2 SSDs that were on the same power cable were unaffected.
I have replaced the PCB on one of the drives using the Canadian outfit PCB Solution but that drive is still dead. I doubt if replacing the PCB on the other drives would yield any different results. Does anyone have a suggestion as to what else I might try with the drive? Or any recommendations as to a reliable recovery company and any insights as to what I might expect there. There is probably another terabyte of data on the drive that I am not interested in, just the 30GB.
Appreciate any help here. David
Sounds like youve tried everything..... if the PCB is dead likely the motor is shorted too.
Which model of PSU was it from Corsair?
I would suggest a recovery company if you absolutely need the data although I am NO expert on HDD's.
yeah if a pcb change didn't help then the internals are pooched. your only option will be a clean lab recovery company, where they can actually read straight off a platter. which will cost a lot, like $500-3500.
I think the Corsair ps was one of the gold series; would have to look thru old paperwork. No new motherboard, only replaced the ps, bad ps cable, hard drives and dvd drive. Should have had the 30gb backed up externally, but in the all the years I've been doing this, I have never lost multiple hard drives at one time. I've lost mother boards and single drives to power surges over both power lines and telephone lines.
Anyone recommend a good recovery company.
So you are on a new motherboard right? Along with the dead drives the motherboard is gone too right?
No, motherboard was not affected. Only the 3 sata drives and a dvd drive on the same power cable went dead. And as I mentioned before, 2 ssd drives on the same cable were unaffected.
I think they are looking for more info or getting at that there could be probs with the mobo/sata ports. how do you know that the problem was isolated to just the sata power cable? does the board detect drives on all the ports correctly? it is odd that that 4/6 devices died on the same cable...
Since everyone is trying to understand what happened, here it is: Initially the machine would not boot; power light would flicker on and then go out. Trouble shooting showed that the power supply was dead (probably one or more of the capacitors). When I replaced the power supply, the machine booted but the 3 hard drives and dvd drive that were on a single power supply cable were dead. Tried the drives externally and they were definitely dead; would not spin up. As I mentioned before the 2 ssd's on the same power cable were not affected, one of course being the boot drive. At this point I installed one new drive on the same power cable and it went dead. Very strange; I could only surmise that perhaps the power cable was shorted. After some more troubleshooting, I realized that the power supply cable was indeed bad (must have used the original cable from the dead power supply). I replaced the power supply cable, installed new drives (recovered all but 30gb of data from external backups), using the same sata data cables, and everything is up running. Drives are being detected properly in bios and windows. Again, the mother board was not affected, nor the ssd drives. This was not an external power hit. I don't claim to understand exactly what happened, but the system is up and running with new drives using the same sata data cables on the same data ports. I've been in this business a long time and have never experience anything even remotely similar to this.
The reason I posted this was to see if anyone had any options for recovering the 30gb of data.
that is weird indeed. ive never seen just part of a cable go bad like that. but all that is besides the point. right now your only option is to weigh the cost/value of a clean lab. just look for a no data no cost one.
