Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
If you really need to know, Graham Alexander Bell created the first telephone (no need to explain how he helped the development of the net).
Morse created Morse code, a system where a combination of dots and dashes created letters, that then formed words (a sort of Binary if you like). They could be sent over telegraph lines to message people, again helpin the development of the net. http://home.austin.rr.com/kinghome/signpage/baudot.html has info on Baudot codes, used in the transmission of messages over telegraph lines, again a sort of binary, but more developed. This was the best example of an early internet by using binary to transmit words.
Hope that helps, but do use google instead of [H] Forums.
