So, the wife and I will be moving to a new place next month, and I'm a bit stumped on how to best get the place wired up. We'll be using cable internet, and unfortunately there is only one cable jack in the whole place - (I looked through twice to make sure I wasn't missing one).
The cable jack is right by where the TV will go in the living room. The problem is, the second bedroom that will act as my office is at the exact opposite corner of the place. Far from convenient.
My current plan is to have the modem/router hidden behind the TV, with a switch that goes to the xbox, ps3, wii, and tivo. The problem will be getting a connection to the office which will have the my PC, our home server, and the network printer. I don't really like the idea of using wireless unless I have to - I'll be working from home part time which will require a VERY reliable internet connection, and I also do quite a bit of online gaming, and I've never known a single person that uses wireless for that be happy with it in the long run.
My current equipment is an Airport Extreme with N, and a 5 port 10/100 switch that I've had since....well probably high school. I'm considering the Netgear HDXB101 ethernet over powerline, but the building we're moving to was built in the 60s or 70s, and I'm sure the wiring isn't new. From what I've heard, older wiring gives pretty poor performance with those. I'm also considering grabbing a gigabit switch and running Cat6 (either between the carpet and wall or up around the edge of the ceiling), but I'm not sure that the wife will love that solution.
A friend recommended grabbing a pair of wireless routers and using one as an AP for the office, but again, I'm not sure I'll be happy with the speed it gives.
I'd appreciate any recommendations. I'd like to avoid buying too much new equipment for this. The apartment is about 1200sq feet, all on one level. Concrete construction. It's probably....100ft or so through a few walls from the place the cable comes into the house to where the office will be.
Thanks
Thanks
