Well, my computer was going flaky on me....doing odd crap, so I did a clean wipe of both drives that had OSes on them (one was Vista RC1, the other XP). Installed XP, got everything in XP working fine, but when I boot, if the XP setup disk is not in a drive, I get a "Startup disk not found" error when I boot. I tried Fixboot with no success. Windows XP will load just fine if the setup disk is in the drive...even when it isn't booted from, but if it ISN'T in the drive, I can't get to Windows.
I am assuming that FixMBR is probably the way to solve this, but the warning is pretty darn scary, and the MS Knowledge base doesn't even indicate whether or not it will fix my problem.
One thing to note is that my OS is installed to the D drive (why it couldn't have made that C, I don't know, but before, it was E and worked fine, so I'm kind of stumped).
So, what's the best (and safest) way to do this. I have 4 hard drives total in the system...two SATA and two IDE. The OS is on the smaller of the SATA drives, if you need that.
