my rig:
asus-sli
amd 3700
7800gt
sata drive
winxp pro sp2
enermax 535w psu
just built it the other day, installed winxp pro sp2, installed drivers ..worked well enough at first then I noticed I couldnt download apps ..every program/zipped file I tried opening gave an error message saying it was corrupt. I cant download drivers, bios updates cuz nothing will unzip/open
another problem ..why is my hardrive recognised as removable media? ..there's a "safetly remove hardware" button on my tray and it shows my only hd ..the sata drive
still another problem ...I'll also have problems viewing large images in browsers ..it's almost as if only part of the file downloads when I view an image
one last problem ..I cant update world of warcraft because I continually lose connection and or crash and re-start all together
I'm pilling what little hair I have left outta my head out of sheer frustration ..if I could install new drivers or update bois at least I'd be actively doing something to figure out the problem ...but I cant even do that
HELP!!! administer a sedative if need be
asus-sli
amd 3700
7800gt
sata drive
winxp pro sp2
enermax 535w psu
