HELP!!! Why is my computer Crashing!!!??
kgeorge78
NEVER EVER, EVER Been this frustrated with a setup!
MSI Neo4 Plat
FX 55
2 GIGS (2x1024) OCZ Platinum
2x 74 Gig Raptors
Enermax SLI 600W
2x 6800 EVGA Ultras
2x6600GTS (MSI)
Everything installs fine. Running any games, benchmarks results in my computer crashing, rebooting or BSOD.
I thought it was the ram so I changed it, Then I thought it was the chip so I bought anohter FX55, Then I heard it was the 6800ultras so I RMAed them and bought another pair, then I heard that there was driver problems with 6800 ultras, so I picked up 2 6600gts yesterday and same fucing problem
Anyone else having problems with this setup??
Using the latest Nvidia drivers from nvidia.com
THanks!
hey man make sure u update ure bios jes in case. also what are the Amps on 12+ rail on your PSU? also is that a SLI PSU??
i know with the asus board i bought i had to put the memory module in dimm slot B1 instead of A1 i dont know of the MSI Neo requires the same thing for a single chip but be cautious of that as well
its mostly restarting, no more BSOD,
The ram is 2 dimms instead of 4 so it should be fine - I installed the ram in the proper dimms as per MSI.
The bios is updated to the latest.
WTF!
I might go back to Intel because of all the problems I've been having with amd
Turn of the Restart Automatically so you can see what the error is.
Go to Control Panel -> System -> Advanced Tab -> under Startup and Recovery click Settings ->under System Failure uncheck Automatically Restart. Now you'll get a BSOD instead of a restart. Write down that code.
Another thing to check is go to Control Panel -> Administrative Tools -> Computer Management -> Event Viewer. Look in System and Application for any errors that happened when it crashed.
I have done that - During 3dmark 03 and 05, it just gives me the standard windows error with the "send" or "dont send" box.
I have tried with 1 card, 2 cards, switched all my ram slots, used 1 dimm, 2 dimms, ...
updated the bios to 3.1 and upped the ram voltage to 2.8 and upped the cpu voltage to 1.6
any help?
my ps is an enermax 600w sli
any help?
are you overclocking this system?
Considering the list of troubleshooting techniques that you've gone through, there's not much more that it could be. So far it would appear as though the only constants are the hardware being used, and the installation of Windows. Since the majority of the tests have been hardware based, maybe its time to look at the software.
Provided that those 2 drives are not striped, move all the data off of the one that your current OS is not on, completely unplug the one you're currently booting from (just in case), and try reinstalling. If the non-OS drive cannot easily be prepped for OS installation, chalk this as a very good reason to have a spare hard drive laying around. --note: by using the other drive, if successful, it makes the data migration game much easier, and saves you from having to go through the installation process all over again--
Try to monitor that installation as closely as you can...You don't have to sit right in front of the computer and look for dead pixels the whole time, but double check to make sure its not abnormally restarting itself during installation and picking up where it left off after it comes back up. If it does abnormally restart, then clear the drive and return everything to the way it was before you started. (rule #1 of troubleshooting, one thing at a time)
I'm working under the presumption that the majority of the hardware in this build is new, so don't rule out the possibility of defective hardware. The suggestion made by dasaint is very important... In my experience, if a system is just magically restarting for no apparent reason, without error code, without warning, it is usually the power supply. Depending on the sensitivity of the system, 2 tenths of a volt on any of the output rails could mean the difference between a happy user, and several hours of frustration. Amps is also something to look at, but I have only rarely seen where a lack of amperage was the culprit. Using a multimeter would be best, but if you don't have one, your BIOS can usually provide an adequate assessment... Adequate meaning "better than nothing" in this case.
There is also the possibility, extremely rare, that both of your memory sticks might have some minor fault. If they were made on the same line, around the same time, and the manufacturer somehow had a bad batch of chips, it’s possible. Instead of jumping into 3dMark immediately, try an aggressive memory scan... The probability of this is extremely small, but for troubleshooting, the more you can rule out, the better.
Oh, and for the record, I've used AMD processors ever since their Pentium-clone days, I prefer ABIT or ASUS boards, VIA chipsets, and I will never buy Intel for a host of reasons, which I will not discuss here because it would turn into a flame war. AMD makes great stuff. If they didn't, they would have gone out of business, merged with another company (like Cyrix), or been forced out of that aspect of the computer market (like IBM).
One final note. Most people shrug off a BSOD unless it's a constant problem. As soon as you experience one, it’s always a good idea to get the error code, and any other pertinent information (like the address, filename, etc...)
Thanks for the nice post! My next step is to reformat using 1 drive and use a different PS
or
Do what I just did - Order a 840 Dual Core EE Based Dell XPS Gen 5
my friend, you have more money than patience.
Hope ya figure it out. You might want to check your temps, though.
i had a problem with a northbridge heatsink that was coming off my old motherboard,
which caused random lockups, and reboots.
pissed me off for over a month.
~spike
go into the bios, change the command rate on the ram to 2T
and i hope to god to RMAed each piece that you thought was bum, if you bought new stuff each time... WOW
I changed the ps, install windows without raid.
During windows, everything is great but once I run 3dmark, CRASH!
The screen turns black and nothing happens usually in the beginning of the benchmark.
I can run all the sandra benchmarks without a problem.
Are there any other benchmarks / burnins I should try for Stability???
~spike
Reminds me of when I worked at a used computer store as lead technician. Received a shipment of Pentium 3 600EB slot 1's (the kind where the processer was exposed) including the stock heatsink and fan from a wholesale vendor. All parts brand new and in package (yea, we sold new equipment at this 'used' computer store sometimes, and yes, it was quite a while ago). Every single one of those heatsinks and their practically worthless little thermal pad were leaving about a half a millimeter of space between the contact point on the processor and the pad, and nobody noticed till the systems we were using those processers in were coming back with lockup issues. Thankfully none of the processors were toast, but it was difficult getting customers to understand that just a tiny little smearing of thermal grease would fix their problems.
Ever since then, in every system I've ever built (for family, friends, or self), if heatsinks can be easily popped off and not broken, and whatever material they use for thermal conductivity removed, Arctic Silver... Because I am not going to lose several hundred dollars worth of equipment just because some company wanted to save a few cents.
Are you still using the 6600's or did you go back to the 6800's ? Did you remember to check for newer chipset drivers or BIOS releases? Have you tried http://www.omegadrivers.net/ yet? If you know nothing about OmegaDrivers, this one person mods official drivers that increase performance, unlock additional tweaking options, and his drivers are known to get rid of some bugs that the developers don't fix for months.
I use an ATI Radeon 9600XT 128m AGP, with a XP 2600+ sitting on a Asus A7V333, 1gig pc2700 and 7200rpm ATA133 drives. Between using the Omega drivers, and overclocking the card just 10%, I was around 30 3dmarks short of doubling my score.
I had this exact issue as-well, so I think I can help you! Did I get the point across! :D . For the first month using my FX55, MSI NEO4 PLAT SLI, G.SKILL ram, 6800ULTRA's in SLI, etc..... MY PC would reboot 100 times, I too would get BSOD's, and mostly LOCKUP's. I've formatted atleast 35 times, I use a 500GB RAID 0 for my windows disks, so I thought this was my issue , so on the next format (about 1 hour later!) I took all 4 of my HDD's out, and re-installed 1 36GB raptor, then continued to install winXP home. I used all current NVIDIA drivers, no BETA's, NFORCE 6.53, & 71.89 GPU driver for my graphics cards. After this format was complete I was hoping for an issue free PC that I can finally play games on, and benchmark. Well, installing HL2 the PC locked up tighter than a frogs ass again :mad: . I finally said to myself, the hell with this, I formatted AGAIN (#36) reinstalled my 500GB raid 0 array, and as I installed WIN-XP, and all the drivers I very carefully thought about what they do, and what they affect. I came down to the conclusion of when I install the NFORCE driver, a screen will come up and promt you to install the NVIDIA SW IDE driver. I clicked "NO", and defaulted to the WIN-XP driver, and BAM, all the issues when away "knock on wood" All this happened to me about 2 months ago, and not one issue yet. Please take this advice, if you haven't done it already.....
kgeorge78 said:
OH MY GOD! IF this works, your the MAN! Let u know tomorrow.
Please let me know.......I just hope I can help you fix this. I know how pissed you must be after spending all that money.....I went through the same stuff. I thought after spending 4500+ dollars, that I was stuck with a PC that couldn't do sh*t.....
well, okay, we could blame it on an IDE driver ;)
Unless i missed something (hey, i'm fresh out of day surgery on my left eye) he hasnt tried a new PSU...
boggles my mind that you've tried a new FX-55, RAM, and Ultra/GT's when the PSU is a far less expensive part to replace.
My girlfriends computer recently had the one stick of RAM die in it. Same type of problems. Obviously, it's not your RAM. Or rather, it's not likely at all... HAVE you tried a 'good' or new PSU? Just to be thorough...
hopefully the IDE driver fixes it :)
dude your so [H] for loging in the forum after eye surgery!!! sorry had to say that, and im out! hope your comp is running fine kgeorge78
soulsaver_8229
ill try it tonight to see - I have 2 high end PSs same prob.
When installing the nvida drivers, there are 4 options.
I SHOULD NOT?? Install the nvidia IDE Drivers or Just the option to install the SW drivers?
Thanks,
Kevin
Thanks,
Kevin
You dont want to CHECK the box at all to install ANY NVIDIA IDE driver.
oh my god thats retarded
I formatted again using raid with 2x74 gig raptors, fx 55, 2 gig ocz plat (1T, only 2 dimms), and an ATI card (just to change it up)
I DID NOT install any ide drivers and the system is running like a champ!!
Gonna try SLI tomorrow with the gts and ultras to see.
Ill let u know!
Ill let u know!
I hope this works for you.....
Nice call on the IDE drivers Newls, hope you really helped this guy out. If I was having problems like you two, I don't think I ever would have thought to not install the nvidia IDE drivers :confused: .
+edit+ you both have too much money, buy me a video card :D
pwease :( ?
pwease :( ?
I might hold you to that :) . I just retired from my old job (Parts store manager) And I now started up a "house-buying, and selling" buisness. I hope this make me a future for myself, if so, Ill be MORE than HAPPY to buy you a video card.....
Ill let u know!
Well, was I right?
It's working so far with a x300 card for now - I'll try it agian with a fresh format and 2 6800 ultras - i think u got it though. Im so fricken tired of formatting and pulling my floppy out.
Im not even gonna raid this time!
If this computer isn't running 100% by Saturday, I'm gonna throw it out my window and drive over it with my 4x4
p.s. - Anyone try a Asus SLI Premium??
You sound like me about 2 months ago. I said too I was going to throw my stuff out the window, but Im glad I didn't. Those NVIDIA IDE SW drivers are CRAP, and cause alot of issue for alot of people. DON'T buy the ASUS board, KEEP THAT MSI, that your using. It is an awesome board, and I have AWESOME OC's with it. I had the ASUS a8n-sli dlx, for 1 week, before I found out that i could only achive a max FSB of 219MHz :mad: . I then QUICKLY bought the MSI, and BOOM 261MHz on the first try. I know there is more room for my FX55, but haven't really pushed it YET :p
along with the sw drivers, I think the IDE Drviers are fuc***ed too.
I only install the smbus drivers when installing the nforce 4 drivers (no audio, no ide, no LAN (I use wireless)
So far so good.
Cant wait to do everything tonight!!
