HELP! Who has a Chaintech VNF3-250?
Awol
Does anyone have a Chaintech VNF3-250 board they could look at? I need the three digit code on the surface mount resistor at location SR502, on the bottom of the board under the Nforce3 chip.
Background:
I recently sold a new Chaintech VNF3-250 motherboard and A64 3400+ CPU to another HardForum member. When installing it, it appears that he accidently left a standoff in the wrong place in his chassis. It damaged two components on the bottom of the board. One can be resoldered, the other is missing. I would very much like to fix the board for him. He spent a decent amount of money on the board and CPU, and I'd hate to see it go to waste.
Hi Awol,
From what I can gather by looking through the back of my case, that resistor at SR502 reads "000". I hope that means something, cause I've never heard of a 0.00 ohm resistor before.
Here's the result of me stretching my digital camera to its limits in macro mode:
SR502_01
SR502_02
Those pictures really don't show you much, but my naked eye and a magnifying glass agree it's 000. Good luck fixing the motherboard.
Thanks! Hopefully, I'll get this one back up and running!
0 ohm resistors are not common, but not rare either. If a board maker needs a jumper or to eliminate a particular component from a finished circuit design, they'll use a 0-ohm "resistor." Since it's the same size as a regular resistor, it can be placed automatically by the assembly robots, where most other methods would require hand-placement.
See "What component has a black stripe in the centre (it looks like a diode)?" at:
http://www.kpsec.freeuk.com/faq.htm
and here:
http://www.koaproducts.com/english/application/ap9.htm
Awol
Bad news:
Resoldered the loose capacitor and replaced the 0 ohm "resistor" with a small jumper. Board still does not POST. Cleared CMOS, tried different CPU, no memory, etc. No beeps, no video, no lights, no spinning fans. Most likely, the extra standoff shorted out that part of the board, damaging it electrically not just physically.
Gave it my best shot. Shipping it back to moggsquad.
Awol
