HELP...Werid problem
WJK0817
while iam playing cs, half life 2, or sourse...
after i play for like 3 min it always freezes and i have to
"ctrl+alt+del" to strat the steam again...
and idea?
Your computer is freezing...please put a blanket on the poor thing :p ;)
hehe, need specs as mentioned. :D
Don't worry, this is normal. All of Valve's games are still in Beta stage, and ou are a beta tester. You may not have known this, buy you are debugging the game for Valve.
^ Wow, that helps a lot. They say sarcasm is the best medicine. :rolleyes:
There's a widespread problem with steam games after the latest update. Valve is aware of it.
By jove he may be right.....
No seriously once you give your specs things will be alot easier to explain.
