hello all, i just recently put together a fairly decent system for the cash...
intel q9450,
foxconn x38a,
ocz ddr3 1333 reaper 2x2gb,
2x asus 4850 (w/ accelero s1's),
and my first ever ssd, for bit under 200 bucks supertalent 60
anyways, i gently assembled the puter into the wee hours of the morning as usual when just receiving a fresh system. I finally finish getting everything tucked away and pretty, recheck all and she wont even post.
from what ive been able to find the bios is a ami, and the led debug codes should roughly match up with their decumentation. I get a d4 code w/ 1 dimm of ram, d5 w/ 2 dimms and had several other codes pop up without changeing any hardware which hits me as odd to receive different error codes w/o changing anything. The D4/5 codes in an ami pdf point to cmos and ram issues, which i wouldnt doubt is part of the problem. also note i havnt flashed bios because i havnt been able to even post yet.
I have sent off a letter for support from foxconn, but after searching for specifics on this board i wonder if i should just rma it and get a more secure/stable board for another 50-100 bucks. (girl will kill me doing this as i have already spent nearly 1400.) The board appears to work for some people fantasticlly and others not at all, and it looks like a good 50/50 have problems (i know that happy people post much less on forums so the numbers arnt nearly accurate).
I guess im asking your opinions on the matter? or if you know the board and find anything glaring that i may have overlooked along the lines of compatability.
thanks in advance for help/opinion
intel q9450,
foxconn x38a,
