i using a toshiba satellite with a 2.8GHZ P4 processor. the thing doesnt seem very stable. it likes to overheat alot when running itunes, firefox, and some other 3rd application....and then just shuts off....
i dont really know what to do or what would be causing it to overheat so badly.
is there anything i can do other than run a system restore and see what that does?
is this a common problem with the p4 in laptops? toshiba laptops specifically?
any info would help.
