Does this sound like a bad dimm???
Okay I think I have a bad dimm....
I have 6 dimm slots, split into 3 channels A B C
A1 A2
B1 B2
C1 C2
If you have two dimms it says to use slots A1 and B1.
I used those slots, no matter what the combo and it shows only 2gb of ram.
I switch one ram over to C1, so im using B1 and C1 and it shows I have 4gb installed.
I try booting with just 1 stick of ram in the A1 slot, it wont boot with any of my 3 sticks. It will boot with all sticks in the other two slots though no matter what sticks I use.
I can use 1 stick in either b1, or c1 and it will boot with just the stand alone dimm. No matter what sick in the a1 slot it wont boot.
A1 A2
B1 B2
C1 C2
