You need to use AsusUpdate utility, this pro will allow you to down grade the bios. Before you down grade make sure you put your overclocking (if there's any) back to stock setting or it causes your board to bricked.Hi, I upgraded my BIOS today, but it is not stable. How do I downgrade? I tried using the flash utility in the BIOS, but it told me the version I have is newer and wouldn't let me update.
