DocFaustus
- Sep 22, 2002
Almost a year ago, I built a system for my friend's younger brother. He came to me the other day saying the CD burner was broke and the system crashes every time he inserts a blank CD. After verifying that it was not a hardware problem (I put my drive in his comp and it did the same thing), I started looking for another culprit.
I noticed his Norton Antivirus was not in the systray running. So I launched it, the program immediately quit. I then tried installing NAV2004 and it did catch the Blaster.Worm but after it was installed, it would not run again.
If you hit CTRL+ALT+DEL it gives you the message that it was disabled by the administrator.
Internet Explorer will not launch. Gives an error
With those 4 symptoms, can somone identify what virus I am up against here and any solutions to how I can fix this?
