Help w/ Esata port
SeattleJo
I recently just purchased a pc (from Ava Direct) with the asus p5ne sli mother board which has an esata port.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131142
I also bought a Seagate ST3500601XS-RK 500GB 7200 RPM 16MB Cache eSATA External Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148154
I can't get the external hd to work through the pc's esata port. I tried going into the bios and enabling the JBmicron sata controller but still can't get the harddrive to work or even show up in device mgr. I also don't think I even see the controller in device mgr.
I then installed a promise sata controller (PCI card) that came with the hard drive and everything works like a charm.
I would rather not have to use the PCI card and would like to use the esata port. Any ideas? I'm pretty much a noob so I may be missing something simple.
Any direction that you can head me in would be helpful. Do I need to install the latest bios (not thrilled about doing this) or could I possibly be missing a driver? I also read somewhere that sometimes there is a hidden bios that needs to be entered into (don't even know where to begin if it did)
Thank You!
Thanks for replying. I checked my bios version and it appears to be the the most recent version.
Any other ideas?
Thanks
You can? or cannot find the Jmicron controller in device manager?
If you cannot, you don't have it enabled in bios or you don't have the driver properly installed.
If you can, check disk management, you may need to partition and format the harddrive. Right click on the my computer icon, and goto manage, then select disk management on the left. Should show up as a drive with unallocated space.
Thank You!
It did turn out to be a driver issue. I reinstalled the driver and everything is now working properly.
