RaceBannon
- Mar 13, 2004
Ooook. I need a little help.
I am not a super hardware ninja, but I've installed a CPU Cooler or two. Never had a lick of trouble until now.
I bought one of the new Aerocool DP-102LE coolers. It seem to have decent reviews on the sites that I found and the temps were on par with some of the best air cooled had to offer. It is fairly heavy, but not overly so. It's got a three pronged clip that seemed OK, but I found it suspiciously easy to clip on the opposite side.
My problem is this: I'm getting OK temps with the tower lying on its side (like an old desktop), but if I try and put the tower upright, the temp increases by 10 degrees or more! Its as if the sink is just barely rocking off the core. Just enough to make the connection less forceful. I've tried putting a homemade shim under the spring clip to make it bend a little more. This helped, but I still get the huge difference in temps.
I'm wondering if anyone else has had problems with the Aerocool DP-102's. And if anyone has a suggestion as to what I could do to remedy the situation.
I'm running:
Abit AN7
Barton 2500+ (not overclocked - not until I get this straight!)
1gig GEIL 3200 Ram
Radeon 9700pro
Thanks in advance for the help!
I'm running:
Abit AN7
1gig GEIL 3200 Ram
Radeon 9700pro
