Ok, here's the story. I work at a computer retailer and they put off RMAing a monitor for God knows how long. So I went into the office and pretty much talked my way into taking it for free. If I can get it to work that would be awesome! This monior, a N1700W, has RF and Component input as well as just being an extra monitor to use. My problem is that it does not power up or show any power at all. I used a multimeter to check Voltage and it is pumping out a decent 12V which I assume is good. I don't know what components to check from here, and what would be financially feasible. I took it apart to make sure all connections were in place, and they look fine. Any suggestions are greatly appreciated.
Thank you
P.S. they had already RMAed it once and the screen itself looks brand new.
Thank you
