I've got an AMD 3800 X2 on ABIT A8N Ultra mobo, XP-120 hs, and a gig of corsair xms3200 ram. However, At 2500 I get CPU temps of over 50 degrees C and need a BIOS voltage of 1.525 V.
Am I doing something wrong or is this just the upper limit of my overclock? I've been told that I shouldn't run my CPU at temps higher than 50 degrees C.
I've been considering the posibility that I misapplied my Artic Silver 5 and I'm not getting optimal contact with my large xp120.
The 120mm fan on top of the heatsink is a generic fan as well, and typically only runs at about 1800 - 2000 rpm.
The reason I ask is I see many in these forums w/ my same CPU but much higher clocks. I was just hoping you guys could offer some advice on how to get a higher clock!
