help! video display issue (gt520 slim)
gabzor
Hey guys i just installed a asus gt520 fanless slim edition in my customer's
HP 8000 elite
i'm trying to power 2 46" samsung led hdtvs being used as menus
i took off the vga bracket, and unplugged the vga, and installed the slim for
the dvi + hdmi
i inserted an dvi to hdmi converter and plugged the 2 tvs
and tried to switch the outputs on the tvs to hdmi..
1 tv worked no problem.. and the other one wouldn't let me switch the source because it says signal is not detected or too weak
i tried switching the hdmi cables, and running one by one with just the dvi to hdmi.. no issues but only works with 1 tv
the weirdest thing is both tvs are detected by the videocard, i can identify displays 1 and 2
(i'm using teamviewer to control what comes out on the menus)
is it because the psu is too weak? is it cause the pci-e is an older tech? does the videocard not support dvi + hdmi? which is weird because it should
i have verified the cables are fine (40ft run inwall)
the dvi converter works too but maybe i need another one?
it worked one time where both displays were working, but 1 still had the warning saying "signal is too weak or undetected" while windows was in the backround! :confused:
need answers asap! thanks!
~edit the dvi to hdmi adapter is DVI-I dual link, perhaps if i get a DVI-D dual link it should be better? (which doesn't make sense) but still
Don't know if it can help but as you try the lastest driver? If yes try another like beta or something older
