Help! VGA to S-VGA
at_viper
I have an S-VGA monitor and only a vga output on my motherboard. I need to go from svga to vga on either end so i can use a vga cable. Does anyone know how i can go from VGA to S-VGA. I have looked all over but nothing really solved my problem. Thanks
I would think a standard vga cable to the monitor should do the job.
Have you tried that? What's the native resolution of your monitor?
S-VGA is three rows VGA is two rows. How does that work?
I think you are confusing a serial port with a video port. There have not been nine pine video ports on computers sense 1992. It was for the old EGA or CGA graphics. If your mother board does not have a 15 pin connector on it, it does not have built in video.
