Help! various questions :)
Min
Dear all.
Hi my name is Min and I would like some advice from the experts out there due to my lack of experience.
Being the ignorant person I am I have been an avid user of Apple Macs for a long time.
The interest in gaming has hit me quite late, and only recently. Hence after much research my eyes have opened to a whole new world out there and I am now a late joiner in the PC building community.
Having spent quite a lot of time in the last few months reading reviews, article, delving in the sea of knowledge on forums such as this one and watching hours of video, I have finally pulled the trigger and built my first PC rig. Yay!
I have taken advice from various sources and carefully thought out what I want and how I want my system set up and looking and picked out parts instead of rushing out in my excitement to buy parts without giving thoughts to how I want my finished build to look like.
Currently I have finished building a fully working rig, but with everything running in stock just the way the parts came. Nothing has been over clocked or modified as of yet.
My rig so far:
Case: NZXT Switch 810 Matte Black
CPU: Intel i5 3570k
Mobo: Asus Maximus V formula
GPU: Asus GTX 670 DCII (Non top version, possibly adding another card in SLI in the future)
RAM: 16gb Corsair Vengeance 1600mhz in red (4 x 4gb)
PSU: Corsair AX850
SSD: Intel 520 series 120gb (I have my o/s and games on this one)
HDD: WD Caviar Black 1TB (For storage of photos, music etc)
DVD: LG GH24NS90.AUAR50B 24x Super Multi Internal DVD Rewriter
O/S: Microsoft Windows 8
Keyboard: Steelseries 6Gv2
Mouse: Steelseries Sensei
So far I have the Rig all built up and working running all stock settings.
Also currently I only have the stock fans set up but just re-jigged the position a little bit.
I have removed the bottom hard drive cage and the bottom bracket.
I have one stock fan on the top at the back of the case on exhaust, one at the back of the case moved as far up as possible on exhaust, one at the front of the case on the top fan fitting and one at the bottom next to the PSU.
Now that I have a working rig my next project is to get all the water-cooling and aesthetic side of the case modified and complete. Once I have a rig which can handle the pressure thrown at it, I plan to start delving into over clocking the CPU and GPU and possibly adding a second GPU to run in SLI.
Okay here is where my questions begin.
I have 4 topics of question:
1. Motherboard power connection
2. Aesthetics
3. Water-cooling
4. Fan set-up and airflow
Starting with a very simple question, how to connect power to the Mobo.
From what I can see the Mobo comes with 4 power connections.
1x 24-pin eATX Power connector
1x 8-pin eATX Power connector
1x 4-pin eATX Power connector
1x 4-pin molex EZ_Plug
Currently I have the 24-pin and the 8-pin plugged in and everything seems to be running fine, but what is the other 2 connectors for? Should I plug these in too?
2. Aesthetics
As you guys can see with the Maximus V Formula Mobo, the Asus GPU and the red ram sticks my PC is predominantly all black inside with red accents.
This is the colour scheme I want to stick with, black with red highlights to catch the eye.
I don’t want to go too overboard on the RED RED RED colour scheme and have a washed out look inside though and I want to be careful of overusing the red colour.
As you already know the NZXT Switch 810 case has a massive window on the side which is what I wanted and love, but this also means I need to take that much more care with how it looks inside.
I have a design idea in my head that I have been sketching out. However, having not built a rig before I’m just a little concerned what might seem like a good idea on paper might not actually look good once implemented so I wanted to pick your brains and experience.
My train of thought is istead of going down the typical LED fan route, I plan to get fans that are more focused around performance and silent operation than just choosing ones because they come with LEDs on them.
Also I feel sticking with the red colour scheme and illuminating the inside of the case with red lights will actually give me a washout affect and ruin the image I’m going for.
So I plan to illuminate the case with white light and provide the red accents.
The red accents I plan on using are:
The red from the Mobo
The red Ram chips
Water-cooling pipes running red water
Red braided power cables for the Mobo and the GPU.
What do you guys think?
Now I found a photo of someone else’s build which is actually more or less the impact and colour scheme I wanted to have.
This is almost my ideal finished look.
Also I am considering having red light accents similar to the photo in the link above.
The mesh running along the bottom of the case, and having a red glow at the front of the case coming from the little triangular mesh at the bottom. If I were to do this, how do I do it?
nzxt-switch-810-full-tower-casing-matte-black-special-edition-lingloong-1208-22-lingloong2.jpg
Would this look weird and would it be better to keep the front of the case looking stealth black having no lights coming from it? Also I’m concerned about light leaking from the air vents down the side of the front fan cover and from the top of the case from the air vents, would this look weird? I’m worried that it would look really odd and ruin the external aesthetics of my build.
Another big concern I have is that when I look at a lot of the photos of other people’s build with LED’s illuminating the inside of the case, there seems to show a very sporadic light with flares and partial patchy bright zones like this one
How do I avoid this and have it looking more like the white NZXT case above and hence what is the best way to illuminate the case from the inside?
Final question on aesthetics is my GPU being heavy and only held up at the front at the expansion slot and in the middle with the PCI slot, the rear end of it is sagging down slightly. But if I see other people’s build even with bigger cards it’s perfectly perpendicular. How do you keep the cards supported like this?
3. Water-cooling
There are water-cooling channels on the ASUS Maximus V Formula Mobo that runs around the CPU block. So I plan to make use of this and have the CPU, Mobo and GPU set up in the watercooling loop.
From researching online it would seem that the loop order I need is Pump -> Reservoir -> Radiator -> CPU -> Mobo fin thingy -> GPU -> Back to pump.
The thing that is difficult for me to get my head around and understand is what size radiator is required for the amount of items on the loop.
So currently I have the CPU, Mobo, GPU I want in the loop plus maybe an extra GPU in the future.
Would a single 240 or 280 60mm radiator up top running a push pull config be enough for this or do I need to either try to squeeze in a 360 radiator up top or instead possibly get a second radiator on the bottom?
Also linked to the Aesthetic side of things, for the water running inside the watercooling loop, I would like to have it looking very much Ferrari red (instead of a pinkish light red colour).
Does this mean I just need to add more die into the water and use a clear tube, or do I need to use a red colored tube?
Finally, as I mentioned all the way on the top, currently I only have the stock fans set up but just re-jigged the position a little bit.
This is what I’m planning to do:
Run a radiator 240 or 280 up at the top right at the back in a push pull config if space allows for it. Add another fan at the top towards the front of the case just exhausting.
Have the fan at the rear of the case exhausting.
Have the 2 fans at the front and 2 fans at the bottom of the case.
Have 1 fan on the top HDD cage pitched towards the GPU and CPU for better airflow direction.
Like this
Now I know that this might be overkill, but then again this is as much as a hobby then just trying to push maximum benchmarking performance.
That gives me a total of 11 fans if I run push pull, and 9 fans if I don’t run push pull on the radiator.
How do you control so many fans?
Am I better off plugging them straight into a molex and into the PSU and running full power all the time?
I have looked at fan controllers online but all of them seem to only support 4 or 5 fans. How do I get this number of fans on there?
Also is this a good airflow configuration in regards to positive / negative airpressure?
Thank you so much everyone for your patience and support.
Min x
Ok...
1) Those headers are for extreme overclocking ie. LN2, phase cooling etc.
2) I would say just use 2 strips of white LEDs... as the one in the white case has white led fans...but if you get them I would recommend 1 LED strip
3) I would recommend 2x 240mm rad at least...pref. a thick one on at the top or a 360mm would be better..
the red in the picture is red tubing...if you get clear tubing and red coolant it would look maybe a little lighter depending on how it reflects the light...if you want solid red then get red tubing and red coolant
edit*
depending on athetics.. I would have res>pump >rad1>cpu>gpu>rad2>res or res>pump>rad2(bottom)>gpu>cpu>rad1>res
4) if you were to get Watercooling then I would recommend 2-6fans(depending on push/pull and 240/360 rad) at the top as exhaust..so
top 2-6 exhaust (rad)
back 1 exhaust
bottom 2 intake (rad)
front 2 intake
and if you were to get a fan controller or fan speed reduction cable(I can't find the one that I was looking for but when I find it I'll post the link..it's a molex and splits to 3 and reduces voltage) and run them at 7v they would be nice and silent...
I'm new as well to this whole scene as well, and even got the same case.
One thing I noticed was your loop order. As far as I know, you should always have the Reservoir before the pump, and not after, as a pump running dry will ruin it.
For comparison, I'm using a 120.3 60mm radiator in pull in the top to cool pretty much the same parts.
I'm definitely following your thread, as you have posted some interesting questions. :)
..lost me @ "color coordinated" be sure the 24-pin power AND the 8-pin ATX (not pcie) connector are plugged in before you fire it up.I just realized..your rig will have [H] colors..lol
Alright guys,
I have had 3 days to go off and plan out my project and at the moment it looks ready to place the order, here is what I'm getting.
I ran into a few problems and these are the things that I had to compromise on.
1) Going to put a 360 radiator up top, so I'm going to have to lose the stealth optical bay just and having to put the optical drive on the bottom bay expose. No biggie, but such a shame to lose such a nice feature.
2) due to motherboard size restriction etc, going to have to go for a 35.5mm thich radiators instead of previously planned 60mm radiators. Instead I am going for 1x360 & 1x240, instead of the previously planned 2x240 60mm.
3) Instead of having red LED strips on the top, I'm going to run push/pull for the top rad and use a red led fan up top. Hopefully, due to red LED on top and then a radiator and then white LED on the bottom, I hope the resulting colour in the case is not pink.
So Here It Is! What do you think?
1x Corsair AX850 Individually Braided Modular Cables in Red (to give that extra red to the colour when plugged into the MoBo and the GPU and coming out the PSU)
1x XSPC 5.25" D5 Dual Bay Reservoir and Pump Combo
1x XSPC RayStorm CPU Waterblock
1x XSPC Razor GTX670 Waterblock
1x XSPC Raxor GTX670 Backplate
1x XSPC EX 240mm Radiator
1x XSPC EX 360mm Xflow Radiator
1x FrozenQ Liquid Fusion V Red Helix
10x XSPC Compression Fitting (Black Nickel)
2x 90 degrees compression fitting (Black Nickel)
3m Primochill Primoflex Red Tubing (3/8 ID - 5/8 OD)
2x Xigmatek Crystal Fan 140mm White LED (For the rear exhaust and one on the HDD cage which will be on low but more for the lighting)
2x Xigmatek Crystal Fan 140mm RedLED (For the 2 intake fans at the front)
5x Xigmatek Crystal Fan 120mm White LED (3 push fans for 360 rad up top & 2 for the pull fans for 240 radiators down bottom)
3x Xigmatek Crystal Fan 120mm Red LED (3 pull fans for the 260 rad up top running in push/pull config)
1x NZXT Sentry Mix 6 Channel Fan Controller
1x Phoya Thermal Paste Cleaner
1x Arctic Cooling MX4 Thermal Paste
Couple of fansplitters to plug into the fan controller
1x 5L distilled water (From Halfords)
1x Mayhems XT-1 Concentrate (Biocide and Anti-corosive)
3x Red LED bulb (1 for the Bay Reservoir up front, one for the CPU block, one for the GPU block)
I'm pretty Psyched about this actually.
Min x
looks good...
maybe, I'm not sure how much you use your optical drive...if you rarely(once a week) use it, you can get and 5.25" external case...and make it an USB optical drive, as I have done this "mod"..to keep the case looking sleek and stealthy :D..and then when I need a CD...I have it under my desk..so it's out of site...
and a 360 and 240 35.5mm rad will be plenty for your setup
