Help Using iMac as a Display for RCA / HDMI
Tchesco
I'm trying to see if there's a way that I can use my brand new 21.5'' iMac as a display for RCA / HDMI devices.
I'd like to plug my RCA Directv box and Playstation into this computer if possible, to take advantage of its great display.
I am aware of the XD, but unfortunately it does not work with the 21.5'' iMac (only the 27'').
Does anyone have any suggestions?
Thanks
There aren't any inexpensive options. Unfortunately Kanex as an example doesn't have anything for thunderbolt in.
So basically you'd have to buy a Cinema Capture device. The least expensive one I've seen is from Blackmagic Design, the Intensity Shuttle for Thunderbolt (there is a USB 3.0 version which I wouldn't use) or Intensity Extreme.
If this is serious business for you, or you intend to do twitch streaming (as an example), then the BlackMagic Intensity Extreme would actually be a very worthwhile investment. But, not cheap.
Not cheap indeed. I'm not sure what twitch streaming is but this is definitely out of my price range. :(
