ImAgainstIt
- Dec 16, 2008
I'm getting these errors in my Event Viewer -
I'm guessing the previous bit was a normal time out.
I'm also getting bsod's once or so a day
I'm running a Core i7 920 D0, over clocked about 3.8ghz, turbo on, 21x179.6
voltage is 1.188V
memory - 7-7-7-24-74 1T 718.2mhz Dram 1.625V | +1.00 VTT
ocz platinum
Motherboard is EVGA- E-758A1
psu - corsair 750w
Windows 7 Home Prem x64 | latest updates
Gfx is gtx 275 and gtx 210, both upto date on drivers
Sound is Asus Xonar Essence
and intel Nic.
Performance power management features on processor 1 in group 0 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
8 of them, each different numbers (hyper threaded i7)
Source - Kernel-Processor-Power
Event ID - 35
Task Category - (2)
Audit events have been dropped by the transport. 0
Source - Eventlog
Event ID - 1101
The driver \Driver\WUDFRd failed to load for the device Root\SIDESHOW\0001.
The driver \Driver\WUDFRd failed to load for the device Root\SIDESHOW\0000.
Source - Kernel-PNP
Event ID 219
+ System
- Provider
[ Name] Microsoft-Windows-Kernel-PnP
[ Guid] {9C205A39-1250-487D-ABD7-E831C6290539}
EventID 219
Version 0
Level 3
Task 212
Opcode 0
Keywords 0x8000000000000000
- TimeCreated
[ SystemTime] 2010-06-01T00:51:27.872420000Z
EventRecordID 6623
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 56
Channel System
Computer Ima-PC
- Security
[ UserID] S-1-5-18
- EventData
DriverNameLength 18
DriverName Root\SIDESHOW\0001
Status 3221226341
FailureNameLength 14
FailureName \Driver\WUDFRd
Version 0
Name resolution for the name www.ntsc.navy.mil timed out after none of the configured DNS servers responded.
Name resolution for the name www.bestbulkregister.com timed out after none of the configured DNS servers responded.
The computer has rebooted from a bugcheck. The bugcheck was: 0x0000003b (0x00000000c0000005, 0xfffff8800142558d, 0xfffff88008bbd1a0, 0x0000000000000000). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 053110-17534-01.
EventData
BugcheckCode 59
BugcheckParameter1 0xc0000005
BugcheckParameter2 0xfffff8800142558d
BugcheckParameter3 0xfffff88008bbd1a0
BugcheckParameter4 0x0
SleepInProgress false
PowerButtonTimestamp 0
voltage is 1.188V
ocz platinum
psu - corsair 750w
and intel Nic.
