scharfshutze009
- May 22, 2010
Apparently I bricked or sent one of my c3560 PoE-24 switches into an ASCII dump or whatever by forcing it into ROMMON mode. Then issuing the command set baud 57600 in to delete the current IOS to free up space for an updated IOS. Then got the following output:
D
Uբ
@Uu �Wת �݀� "(� �� ��( u
�� �}�* U T� �T]UE�� ���W �� U��Qi �@AW�� (
E
A
5�
Then I found this guide:
Recovering Catalyst Fixed Configuration Switches from a Corrupted or Missing Image
,which is supposed to fix it. However it's not and gets stuck at this part:
switch: flash_init
Initializing Flash...
flashfs[0]: 1 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 7430144
flashfs[0]: Bytes available: 8568832
flashfs[0]: flashfs fsck took 14 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
Setting console baud rate to 57600...
, but it's supposed to display this:
switch: flash_init
flashfs[0]: 21 files, 2 directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4499456
flashfs[0]: Bytes available: 3241984
flashfs[0]: flashfs fsck took 7 seconds.
...done initializing flash.
Boot Sector Filesystem (bs installed, fsid: 3
Parameter Block Filesystem (pb installed, fsid: 4
How do I get it to stop displaying this:
after this:
I would ask Cisco for help, but they are closed right now and probably won't help me anyway because I'm not a Cisco partner considering I don't own a business. I bought the 3560 PoE-24's Refurbished without a service net contract, which wouldn't be available for these things anyway because their end of Life considering the 36xx's series replaced them. I tried to update IOS because I thought I needed 12.2(46) and only had 12.2(35), but the other three allowed me to do Lab 2.1 in version 6 of the Lab Manual. However, if I need 15.0(3) to do labs from version 7 of the Lab manual for IP Switch I'm outta luck because I can't afford even Multi-Layer 3650's at this time or anytime soon enough as far I can tell and those are the cheapest Layer 3 switches with that IOS as far as I know.
I'm a student at a pretty major University right now, so it doesn't seem practical for me to become a business right now. However, the school is limiting me to only using their equipment during open lab, but what if I need to get something done earlier in the week and how am I supposed to know in advanced if the Open Lab gets cancelled becuase its not posted on the student portal or emailed to all IT students who need to know. I've addressed my concerns to the faculty and staff, but they seem to just expect me to deel with this like everyone else. However, I know other students who pretty much did the same or I think already have a business, so why talk me out of it and make me do things the hardware with all those restrictions. After all these things are not connected to the internet and it's hard to say if they ever will because I don't know if I'll every get to use them for my business in time or even want to for that matter.
Packet tracer can only do CCNA level stuff and Virl is out of the question to for the above reasons as well as because my School is not officially part of the Cisco Academy if I'm not mistaken. Also, Virl is also out of the question because I can't successfully log in without the page locking up, so that I can buy the academic version.
D
Uբ
E
A
5�
switch: flash_init
switch: flash_init
after this:
