I got a power supply out of an old PC a friend had (which I know to be working properly as I saw it running the PC in question) and decided to make myself a little test PSU for testing circuits, fans, lights, etc. I removed the top of the PSU, cut all the extra wires and wired the green wire up to ground as I've seen done in a couple of HOWTOs, but now it doesn't seem to be working. When I connect the power cord to the back of the PSU, the PSU fan moves maybe a quarter of a turn and then stops. I checked to make sure that none of the cut wires are shorting out and everything looks fine. Is there something I'm missing? Are there places I should take readings with a meter to help diagnose the problem? I should note that the fan ran fine when I did the old green-to-black paper clip trick.
Any help would be appreciated. Thanks in advance.
