Help troubleshooting computer
n64man120
I spent yesterday doing wire cleanup on my computer and now i cant get anything to come up on the monitor. I personaly think by process of elimination that theres no other possiblility but a messed up mobo... but I would like your oppinions
1) I removed floppy, HD, Optical IDE's to eliminate that variable
2) I unplugged all extra fans and am just running with it open
3) I tested another video card and problem still occured so thats not it
4) All fans turn on, the power lamp on the mobo turns on
But when i turn it on the fans just start to spin and nothing happens really, no special BIOS beeps... it just sits there and screen is black
PLEASE HELP!!! :eek:
ive seen similar probs , if all you have tried has failed ,
remove mobo and set it up "sans" the case.
you may have a hidden ground some where
Remove the vidio card and boot it up.
Do you get the bios beeps for a bad vidio card.
Try the same thing with the ram.
Have you cleared the cmos.
Luck.......:D
Thanks for the tips... turns out i just pulled the battery and reset everything. Odd... i have no idea why that would have effected anything but it worked :D
