Raines8416
- Jan 31, 2004
I got an EMachines T1842 here I need to fix.
I got it with a note "Will not turn on". So I plugged power cable in and there was an immediate humming from the power supply. I turned it off opened the rig, took out the PSU and there was a loose peice inside. It was a small capaictor had broken off.
I thought I had the problem solved, ordered a replacement PSU and put it in today.
Only problem is, computer still wont turn on. Plug everything in and flip the switch on the PSU and it immediatly starts running. LEDs on the front of the case all turn on, all the fans start including the heatsink fan. Power switch on case does nothing, and there is no video or anything. The PSU runs but the comp does not boot. No bios beeps or anything.
So right now, its looking to me like the PSU took the mobo with it when it fried. Hence why the PSU just runs and is not being controlled by the motherboard. Does this sound like a good conclusion?
