Parmenides
- Apr 25, 2006
I have a problem on my computer where my game (Oblivion) preformance significantly drops at random times. Normally, things run fine, then suddenly I hit a brick wall. I can sometimes happen within minutes of gameplay and sometimes within hours. Exiting the game and going back in won't fix it. Only rebooting the computer fixes the problem.
When this bug kicks in, my GPU fan and CPU fan slow down to a relaxing speed as fps drop. There is a second audible indicator of the bug: I have a noisy little toroidal transformer. Thanks to pstang for pointing it out.
These puppies squeak more when under load, mine normally gives minor occasional squeaks. When this bug kicks in, however, one of these transformers go crazy. When I exit the game, every action is still a lot more squeaky. Even moving the mouse causes squeaking, which does not happen under normal conditions. Now, I'm not as concerned with the squeaking. As soon as I figure out my other problems, nail polish remover should do the job. What I am concerned about is that this squeaking is a symptom of something going wrong. Do you have any ideas what is going bad?
A lot of people are on the Elderscrolls forums with this same sudden-drop-of-performance-after-time problem. Most people guess that it's a memory leak problem. I have 2 gigs of memory, so I'm not sure about that.
Any trouble shoot ideas? The time before this bug kicks in is getting significantly more and more shorter. Any application, not just games, runs a lot slower after this "thing" kicks in. I am constantly forced to reboot, which is my only solution to the problem.
