I just reinstalled Starcraft on my ultimate X64 system. But when I go on bnet, it shows me a update msg, and after the update has finished downloading, it gives an error while being applied, here's the error from the update log
Everytime I run it it's a different file that causes the error.
Thing's I've tried so far..
1. downloading the patch from blizzards website and applying manually
2. uninstalling and then clean re-installing the game
3. installing under program files and under other folders/drives
4. googling for the error and looking through bnet's tech support forums
still, nothing had solved the problem...
anyone's got any ideas?
Blizzard BNUpdate v2.133 compiled on Jul 24 2008
Log created at 5:05 pm on 01/18/2009
This patch upgrades Brood War from version 1.04 to version 1.16.0.
ERROR: unable to move original file 'C:\Games\Starcraft\maps\(2)Road War.scm' out of the way (183: Cannot create a file when that file already exists.)
RESULT: Patch failed
ERROR: unable to move original file 'C:\Games\Starcraft\maps\BroodWar\(6)Hypothermia.scx' out of the way (183: Cannot create a file when that file already exists.)
