HELP! Tracking down a fan...
Copyright
I picked up a set of very nice Italian made Mosconi amps.. when taking them apart I found the fans were damaged. I found only a single person selling these.. trying to find an alternative person as I don't trust the site I found them on. Thanks in advance for any help!
DF126010SL
60x60x10 2pin
^ Agreed. The image results for the model number show fans with either bare wires or what looks like Molex small or tachometer Molex small connectors.
The original fans also found in the link above but at 18$ a pop that was a bit much. I got a pair of detla with the same specs for 11$ shipped for both. They have bare leads so I will have to solder on the connector. No big deal.. Thx for the help!
that's just a standard 60x10 12v fan. I did find that fan here: http://www.dhgate.com/product/original-top-motor-6010-6cm-df126010sl-sleeve/263412144.html
but you can just get any 60x10 that matches spec to replace it. maybe you'll have to swap the connector or pull off the socket so its just pins. you could get something like this: https://www.amazon.com/6010-60x60x10mm-Brushless-Cooling-Blade/dp/B00KIDDEP2
Yeah, that's the single person I found selling these fans lol. That same person has the same picture on a few sites selling them. 18$ was just more than I want to spend considering I have spent enough already lol.
