Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Surprisingly AS5 Still holds its own... after its extremely long curing time. Much better though to go with something modern that requires little to no curing.
A well applied paste is much more effective than an an expensive one.
The oldschool p4 I use at my shop actually has hedgetrimmer gearbox lube (essentially lithium grease) as a thermal paste. Been 3 years now. Dont give 2 craps about the temps. Works just fine
