rickyman123
- Dec 5, 2007
i am looking to buy either 9800gt, gt 240 or gts 250 for primary. i want to buy another card for physix card. which card is better for it. 9600gt, gt 220 or 9500gt.
if i put the gt 240 and 9600gt, what driver do i need to download in order to get the physic video card effect.
i have amd motherboard, will it works?
also does it matter if the slot is 16x or 8x?
Realistically, I'd say no. Though you'll need a 16x PCIe 2.0 slot to get the maximum performance from newer generation cards like the 5870, it only impacts your performance by one or two FPS at the very most if you use an x8 slot.
