bigredstylish
- Jun 13, 2012
Hi. I have $500 now and need a computer. I will have more money later and would like to upgrade it then but need to use the computer now. i would like to have a fast processor if possible
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? Etc
- For the next 3 months I only need it for word processing- but after that I am going to have it permanently connected to two screens- one of which is my tv and use it for movies, internet, several other applications. I would like the ability to upgrade it in the future and hope to keep the computer for this purpose for at least 3-4 years.
- my current budget is $600. I will put more money into the machine later to upgrade it after 3 months.
- I live in TX
- I’m a newb so I may be leaving something out but I need the: case, mobo, CPU & fan, RAM, videocard, PSU, HHD, and CD/DVD, network card
- I have the tv/monitor, speakers, keyboard, mouse and software.
6) Will you be overclocking?
- probably not
- I currently have a 24” that is 1980x 1080 and 55” 1080p TV. I will most likely be getting a higher resolution monitor to replace the 24” after 3 months
- I will build the barebones or whatever is possible with a budget of 500 ASAP to use for word processing and internet. After two months I can will have more money and can upgrade the harddrive and memory or whatever else.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
I would like usb 3.0 – don’t really know what else would be helpful. I plan on hooking it up to several monitors at the same time. I also have a macbook and laptop and want to use this computer as the central backup/hub
Yes I have a transferable OS license 64bit
- I live in TX
- probably not
