BulletinBored
- Oct 5, 2004
I just put a Zalman CNPS 9500 on my 3800+. I put a BB-sized dot of Arctic Silver 5 on the center of the processor and pressed the fan on top of it so that the paste would spread out under the pressure of the fan. I spun it a slightly in both directions, and screwed it down.
This method was recommended by Arctic Silver. They say it reduces air bubbles. However, you can't tell if the paste is completely covering the CPU after all the shifting around that took place while I was screwing the heatsink into the retention bracket. I'm contemplating doing it over with the traditional method: spreading the paste out with a plastic trowel of some kind, and then placing the fan on top. At least that way I'll know there's proper coverage.
So if you're still reading this, I'm getting 30C idle and about 40C load. They're good temps, but people are getting under 30C idle with that chip! That's why I'm concerned with the thermal paste application. Will it make that much of a difference?
Sorry for being so long-winded. I know you're all probably busy.
