Help the Beep Codes are driving me nuts.
Scorpionjwp
I have been building computers for awhile now, but I have never came across this beep code.
Here is my Hardware:
Intel Srka4 Quad P3 Xeon mb, link here: http://support.gateway.com/s/Servers/COMPO/MOTHERBD/4000662/400066201.shtml
it is a later revision, so it is missing jumpers.
4x P3 500mhz 1mb Xeon's
1gb pc100 ecc memory
The beep code is as follows: 2-2-3-1 beep code
I turn on the server and it displays the beep code but no video or nor does the num lock light up on the keyboard. I have tried with basic diagnostic, I have another pc that has p3 xeons, so I have tried the processors from this pc to the dual pc. There is no problem with the processors or the memory.
I have pulled all of the pci add-on cards out of the pc, have reset the bios, taken the cmos battery out and put it back in.
I am a wits end with this, I have no Idea what this beep code means. The only thing I get from Gateway's site is: Test for unexpected interrupts.
Anyone that knows beep codes, could you help me explain this beep code.
If you have a pci card in your system (or more than one) try moving it to another slot.
That has been done already, I took out all pci cards and just have the bare minumum running, but it still does this beep code. I tried moving the pci cards around.
I had it running on a 2-port kvm, for a second I was able to get video, then it turned off. I emailed Gateway of the problem, but having to wait for them to email back sucks. I hope someone here that has experience with beep codes please lend me a hand.
A person who has links to beep codes don't help me much, I want a person who has been down the road of knowing what some of the beep codes mean.
http://www.computerhope.com/beep.htm
2-2-3-1 Test for unexpected interrupts.
It is, what it is, and interrupt error.
If there are no PCI boards in the system and you are still getting this it's likely a mobo issue.
Reset the BIOS.
What changed from the last time this was working?
This is the first time, I had this problem, I had just got the processors last week and already have memory for the pc.
I do have a spare motherboard laying around, I will give the spare a try to see if the results repeat.
Sorry I wan't clear, I had gotten a whole server minus the processors and memory from a seller on Ebay. I inspected the server when I picked it up in Columbus, OH, however they didn't have the processors or memory to test it there.
Give me till the end of today to get back with results to see if the one in the case is bad or it might be something else.
I suggest google, a little google goes a lot farther than insulting people trying to help you. Its an interrupt problem hence me telling you to move cards around. Figure it out yourself, have fun. Oh, if you find this guru of beep codes, let me know, because I cant think of anyone who has the time or want to learn all the various beep codes by memory.
I tried google, hence making this thread, I first use google to search, If I am still unsure I post my question here.
Ok I tried the replacement board and I still get the same problem of the 2 beeps, 2 beeps, 3 beeps and one short beep.
The replacement board I used is fairly new and haven't been used. When I turn on the server, the cd-rom tray comes out and slides back in, it does this a second time and it beeps. I am able to try the keyboard and I can get the numlock to turn on and off. Even at one time, I tried a 2-port Kvm switch, I couldn't get any reply on the mouse or keyboard, so I plugged them straight to the pc, at which for a second the monitor went off of standby mode and came on, then went back off. Here is the interesting part, there is a bios recovery option on the mb, I switch to that jumper and the server quits beeping, but I still have nothing for video, the monitor is in standby mode. I tried a second monitor to repeat the results, the same thing.
Here is my findings:
Tried 2 motherboards- same problem.
Tried all 4x P3 Xeon 500mhz in other computer- no problem
Tried the 1gb of pc100 ecc in other computer- no problem
Tried all other pci add-on cards in other computers- no problem
The hot-swap fans in case work.
Got off the cell phone from the Gateway tech support some hours ago.
We are sorta pinning it down to the power subsystem, or power board that connects the redundant power modules and the motherboard together.
