Help! T610 camera TOTALLY messed up! Help!!!
Mark Larson
Help! My girlfriend's T610 is on the fritz!
Back story: We were taking pics of each other earlier today, and set the phone aside after admiring them. Later on, we tried it again, but the picture was all messed up, almost as if the camera was detecting infrared instead of normal light.
We set it aside again, after messing with the camera settings didn't yield any results.
Fast forward to later the same night, after taking some very satisfactory pics with my T610, we decided to take some with hers. The same problem came up again. I tried to mess with the settings, but nothing helped. I even did a Master Reset. Nada.
Now we are really worried.
As you can see from the photos, we have stupidly erased the T-Mobile logos from the phones so we're not even sure whether Amazon.com will take them back.
I'm at wits' end and don't know what to do. If the phone can't even be repaired under warranty because of the missing logo, we are well and truly ××××ed.
HELP!!!!
Download video (6.5 MB or so)
PS: We are 110% sure that the "Negative" setting is disabled. This thing is totally different from the Negative setting. There are horizontal lines all over the display, the display colors are all messed up, and it just doesn't look like the same phone anymore.
I've switched off the phone for the night, praying for it to be right in the morning, since a minor miracle looks like the only thing that can help us.
If worse comes to worse you could always try to buy something like this and switch the cases so it has the logo.
It looks like it's taking a negative... can you upload the pics instead of taking a pic of the LCD?
[edit]after looking at the options, check Options> Camera> More> and look to see if any of those are turned on especially B/W or negative.
on the cameara screen goto more > effects > none
The camera pretty much bites in this phone anyways...I dont even use mine accept when I'm bored and then delete them right away...
