HELP! System Front Panel (power switch) Problems!
mknlb50
Hi. I recently purchased a used cpu/mobo combo (AMD64 2800+ and K8MM-ILSR) to replace my old intel P4 computer... and I noticed a major difference on motherboards... its front panel system connector is different... as you can see here...
(56k warning)
http://x007.uploaderx.net/x/comparison.jpg
top: my old intel P4 motherboard (p4s533-vx)
bottom: k8mm-ilsr (amd mobo)
i was wondering what i should do to get the power switch working!
or where can i get a connector that fits AMD motherboard's front panel connector??
thank you!
unfortunatley you are at the mercy of a standard that never became a standard. Motherboard manufactures seemed to never figure out that a standard connector for the basic front panel controls and LEDs would be a good thing.
There is not a standard AMD motherboard connector. What you need to do is rewire your existing connector to match the pinout on your motherboard. As I cannot see your existing connector I can only assume its of the standard type used. If so if you look on the sides you will see a small square or rectangular hole and some of the metal of the pin. Close inspection of this area will show that on the side of the hole closest to where the wire enters the connector the plastic seems thinner, this is a little flap of plastic that when the metal connector is inserted into the plastic carrier, drops down and captures the pin. With an exacto knife or razor blade gently work the edge under the flap and pry it gently upward just a bit and the internal metal connector can then be pulled out of the carrier. Once you have them all removed to insert just pop them back in the position you need them in to match the new board.
Of couse if you dont see the hole in the side or the connector is molded etc. you are screwed and must cut the old plug off and attach individual connectors and housings, this typically would require soldering.
one of these could be spliced into your existing wiring as well.
http://www.allelectronics.com/cgi-bin/item/CON-2410/189/10-PIN_CONNECTOR_W__HEADER,_.1"#34;_SPACING_.html
single ones are available as well
you could cut and splice this on in for the speaker connections
http://www.allelectronics.com/cgi-bin/item/CON-88/189/2_8-PIN_CONNECTORS_W__HEADERS_.html
those motherboard pins are standard .01 square pins on a .1 inch grid spacing.
how would u know which color lines are responsible for power switch>?
there are 8 lines total...
you got the old board pinout, and the connector is in your hand. The connector should be keyed to only fit one way, or has a mark indicating pin one. match em up and write down the results and to double check look a the rear of the on/off and reset switches.
If you dont know how to take the front fascia off the computer to look at the rear of the AC switch, you need ot just take it to a computer shop with the a printout of the diagram you posted and let them do it. Shouldnt cost much.
