Im new to this overclocking thing, so bear with me I have two systems that Im overclocking, and Im getting weird results with Everest for both of them when I do. Im running the Everest memory read, write, and latency benchmarks for each system, and what is strange is that the memory read benchmark actually gets worse when I overclock. Any idea why that might be happening?
Here are the details:
System 1: P4 (Northwood), 3.2 GHz, 1 GB RAM, Asus P4P 800 deluxe. On this system, Im using the Overclocking menu in the BIOS to overclock by 5% and 10%. For the 10% overclock, Im loosening memory timings slightly no change for 5%.
Overclock results: (all are Memory read (MB/sec) / Mem write (MB/sec) / Latency (ns))
Normal speed: 4839 / 1536 / 77.4
5% OC (3366 MHz): 4486 / 1602 / 90.1
10% OC (3533 MHz): 4413 / 1577 / 89.8
System 2: P4 (Prescott), 3.0 GHz, 2 GB RAM, Abit AA8XE. On this system, Im using the Abit OC Guru windows-based program in Turbo mode an 8% overclock.
Overclock results:
Normal: 5900 / 2014 / 92.4
8% OC (3238 MHz): 5864 / 2020 / 87.5
The memory write bandwidth decreases with the higher overclock in every case that makes no sense to me! Shouldnt memory bandwidth increase with increasing FSB frequency especially with no change in memory timings? There must be something about Everest that I am not understanding Any help is appreciated! By the way, neither system has any trouble booting into XP or running anything at these overclocks, and the CPU temps dont get all that hot (never above 50C), if that matters. Thanks!
Overclock results:
