Help: Soyo Mobo USB headers not working (pic)?
Hey guys,
A while back I bought a soyo barebones system, mistake #1lol. Within the last month I just bought a new case, and put the mobo from the barebones kit in it. On the barebones case there were front USB inputs, and there are front USB inputs on this case too (Aspire X-Dreamer), but they don't seem to work. I've plugged the usb thingies into the mobo every way possible and it still won't work.
Here is a pic of how it should be plugged into the board in the manual, and the tips of the female connectors from the case:
I don't really understand the pin numbers and what the manual is trying to say. The front usb worked on the barebones case, but not in the new one (the old one had seperate little connectors for each wire, while the new case just has a blocked together plug) Are those things in the right order on the block plug? If not, I guess I'm S-O-L. If they are in the right configuration, are the ports bad on the case? Any help is greatly appreciated!
Thanks
-Matt
The wiring looks correct.. So assuming that you have found pin 1 and matched that to the power pin with the power pin... im not sure whats wrong.. Is it enabled in the bios and windows?
The pins on the Mobo looks like:
Are the pins numbered like this?:
13579
2468
I've put the plugs on every way possible, I guess I should check bios, lol, I'll let u know what happens, where do I check in windows?
I own a SOYO KVMP-2 motherboard, and trying to hook up the front side USB was insane. The manual you showed is the same as mine, and none of the labels match anything on the cabling. Its a matter of trial and error, though I got mine to work, kind of. It doesn't seem very stable, in that anything connected to the front USB sometimes stops working. I also think it doesn't run at 2.0. Anyways, SOYO should be slapped for non-standard labelling.
Well it did work in the case it came w/ and it was USB 2, but I can't get it to work in this new case, any suggestions?
You say the pins look like this:
Plug the connector with 5 leads onto the 5 pins.
Plug the connector with 4 leads onto the 4 pins.
Make sure the red is next to red, white is next to white, green is next to green, the thin black is next to thin black and thick black (more like a matt-dark-grey) is next to the missing pin on the strip of 4. If you follow that rule, there's only ONE way round the leads can go - you cannot go wrong.
Count yourself lucky, on my case they were split into the individual strands (9 leads), as were the front audio ports (10 or so leads). A complete nightmare. Got the them all right first time too...all it requires is patience.
Ok, something weird just happened, I plugged em in like Colin said, and nothing worked. But one time I plugged the cable in for my TI-83 calc and it recognized that something was plugged in, but there with a problem. I unistalled all of the drivers, then restarted. Same problem, nothing recognized, and it won't recognize the cable again. Anyone have any insight to what is going on?
