so i quicky scrapped together some parts to build my brother a comp last night and something strange occured when I try to power it up when i was finished.
it would turn on for about 5-8 seconds and then shut off.
the only way to try again was to shut off PSU then turn back on then try again.
i was diagnosing and enabling / disabling things one at a time and discovered that if I set the mobo FSB jumper to 100MHz (as opposed to 133MHz), it would boot up fine into BIOS.
I tried different configurations and sequences with resetting jumper and switching from 100 - 133 and same result every time.
133MHz = shut off about 5-8 seconds after powering on
100MHz = powers up fine, BIOS, beep etc.
here's the mobo I'm referring to and some copy and paste specs:
(I circled the jumper and attached an excerpt from the manual).
btw: I've got an XP 2800+ and 1GB ram (2x512) + Antec Truepower 380W hooked up to it right now...
* CPU Supports Socket A for AMD® Athlon/Athlon XP/Duron processors @FSB 200/266/333/400
* Supports 600MHz up to Athlon XP 3000+ processor or higher
* Chipset nVIDIA® nForce2 Ultra 400 Chipset
* Supports DDR200/266/333/400
* Supports external AGP 4X/8X
* nVIDIA® nForce2 MCP-T Chipset
* AC97 Interface supporting up to two concurrent codecs
* Ultra ATA133 for the fastest hard disk throughput
* USB 2.0 EHCI/1.1 OHCI controller
* FireWire® and USB 2.0 for the fastest digital connectivity
* Audio Processing Unit(APU) encodes audio in Dolby® Digital 5.1 format for full surround sound effects
* FSB FSB 200/266/333/400 MHz clocks are supported
* Main Memory Supports six memory banks using three 184-pin DDR DIMMs
* Supports up to 3GB PC3200/2700/2100/1600 DDR SDRAMs
* Supports both 64-bit and 128-bit DDR SDRAM
* Note: nForce2 does NOT supports x4 memory device. 1GB can be made by other density of dram chip such as x 8, x16.
* SLOTS One AGP (Accelerated Graphics Port) 1.5V 4x/8x slot
* Five 32-bit PCI bus slots (support 3.3v/5v PCI bus interface)
* One ACR (Advanced Communication Riser) slot
* BIOS The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
* The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
* On-Board IDE An IDE controller on the MCP-T chipset provides IDE HDD/CDROM with PIO, Bus Master and Ultra DMA133/100/66 operation modes
* Can connect up to four IDE devices
* Serial ATA Interface Support 2 serial ATA plus 1 ATA133
* RAID O or 1 is supported
* RAID function works w/ATA133+SATA H/D or 2 SATA H/D
* In-Chip IEEE1394 nVIDIA MCP-T IEEE1394 controller
* Support up to two ports via external bracket
* Network Chipset integrated 10/100 Base-T Ethernet/Fast Ethernet
* Audio Realtek ALC650 6-channel audio
* Dolby Digital 5.1 format
* On-Board Peripherals 1 floppy port that supports two FDD with 360KB, 720KB,1.44MB and 2.88MB
* 1 serial port
* 1 parallel port supports SPP/EPP/ECP mode
* 3 audio ports in vertical
* 2 IEEE1394 connectors
* 6 USB ports (Rear * 4/ Front * 2)
* 1 RJ-45 jack
* 1 serial port
* 1 RJ-45 jack
