Disregarding the other details of my situation, let's just say I need to remove my Thermaltake Silent Boost K8 cooler from my Athlon64 3200+ and both from an ASRock 939Dual-SATA2. One small problem; it doesn't come off.
Used AS5 originally on chip, used the recommended "grain of rice" amount, has spread itself out over time. Chip would run at about 35 C round the clock before dead motherboard necessitated the removal of said CPU.
Cooler "turns" about...20 degrees in each direction, but sufficient lifting force is not possibly to remove the damned thing. I've had a few of my fellow computer-savvy friends attempt to remove it, to no avail (and we've all had experience with Socket A and Socket 939 coolers).
Any input would be greatly appreciated.
Thanks!!
Thanks!!
