Help setting up the drives on my computer
Lyrids
I got all my parts late last afternoon and spent most of the day putting it together (it was my first time). Nearing midnight I was getting pretty tired, but I was pretty much done. I connected all the cables and tried booting up. I was just glad enough to get it to boot but it hanged at a screen stating my motherboard model in the background with a design, and on the bottom it said press tab to switch to POST and delete to go to BIOS setup. I couldn't get this to work. I was told it was probably a drive issue so after some jumper changes and mixing and matching I was able to get the HDD to connect but not the DVD RW drive. Right now I have the jumper setting on the HDD set to CS but I'm being told I should take it off to find something else that works. Anyone have any suggestions?
I forgot to mention specs in case that would be helpful in this situation
MSI K8N Neo Platinum
Athlon 64 3200+
2 x 512 MB Crucial PC3200
Western Digital 160 GB HD 8MB Cache
NEC Dual Layer DVD-RW Drive
Currently have a GeForce3 in there
Set your drives to master and slave.
Also, make sure you keyboard and mouse are plugged in to the correct slots and plugged in all the way.
EDIT: WD drives, when they are the only device on an IDE channel, require that no jumper is used.
Also make sure your IDE cables are plugged in the correct way to the motherboard
I need to know what I should set each drive to though. So I guess I'm just going to take the jumper out of the WD, but I still don't know about the DVD RW. I'm getting more worried about this drive because now it won't eject when I turn on the computer. As for the keyboard and mouse thing it's weird because sometimes it works, sometimes it doesn't, and sometimes it just takes a while for it to respond. I hope I haven't just screwed something up :(
