- Sep 26, 2008
So I've been using only the GPU client for the past week or so (the CPU client was giving me a hard time). I tried getting it setup to use both but it's never worked correctly.
AFAIK, you only need to disable SLi and run a second instance of the software. When I do that, it tells me that it can't retrieve the work or it starts crunching and gives an error (and resets the other clients work back to zero as a result). I've tried running the same program twice (from same folder) and tried running it from 2 separate folders, both neither work.
I've read that you need a dummy plug for the second video card on an SLi setup, but what about the 295? it's the coop card so it only has one PCB
am I missing anything else?
thanks in advance
cheers
thanks in advance
cheers
