fastfood15
- Jan 6, 2006
So I'm trying to set up a server just for random fun. I had messed around with Ubuntu a little before, so I know that it's well run and supported by a lot of people. I decided to give Ubuntu server a go.
I came across this tutorial and decided to give it a try.
I had downloaded the new Feisty Fawn beta server edition the day before, so i decided to use that instead of the release used in the tutorial. That might of been my mistake, but I assumed things could only be made easier, i guess i was wrong.
So i installed that server distro of Ubuntu. After installing the base system it gave me the choice between installing a DNS server and a LAMP server. I know that LAMP is a bunch of things already installed. So i googled around for tutorials about setting a server up like that. I tried to follow those instructions, but they didn't seem to fit and didn't work out (i got errors and such).
I went back to the original tutorial and followed that until I decided that I must be messing up to many things. So i came here to ask for help.
So,
Is Ubuntu Server any good?
Is it ok that i used the latest release?
Should i install a LAMP server or DNS server?
Is there a better tutorial you would recommend?
Is it ok if i have my server plugged into my router? (When ever i try to go to my ip I am asked for my router username and password. That's not good is it?)
How do I put my website files onto the server?
Will the server just be my ip address?
What's your favorite color?
Is there a graphical server client?
Do i want php4 or php5?
BTW, i don't know if it matters, the computer I am trying to turn into a server is kinda old. P3, i think 512m ram, and 20gb hd. Is there a more ideal server client for low-end computers? I assumed the computer doesn't need to be powerful if it's just me playing around with it. No serious traffic.
Thanks for the (to be) help.
So,
