help set up on horde etc
Rydawg5143
Trying to join the team with my computers, downloaded and am running the gpu client. How do i get setup on the Horde site?
? you mean the team, you want the points to go to the team?
if so, just enter the team number (33) right under where you put your name on the config screen
what name did you put down in the folding app?
I'm not registered there I think, but I still check my stats there, on the left side there is a bar and one button is F@H stats or something, click that, then search your name, and your good (thats all I do)
To get your Stats ID, first you must return a finished work-unit back to Stanford.
Give it a few hours for points to be awarded and work through the system.
Once you have some points to your name, then you can look up your name at [H]ardfolding.
Click on the badge colour you want and you'll see your Stats ID on the left of that page.
Ps. Welcome to the [H]orde.
Luck ............ :D
Thanks for the info guys. WIll check back in tonight.
Is there a certain amount you have to fold to get Genmay access? I have access now but its coming up and say foldign = genmay and folding = win so good all around
I think its .......
500,000 for 1 years access.
1,500,000 for lifetime access.
Its either in the stickies here or over at [H]ardfolding.
Luck ......... :D
Don't want to thread crap, or jack this thread, but why @HardFolding my ID shows up twice. I've been folding on and off, since I keep my PC off more often these days. Also the GPU client doesn't work with ATI 9.3 drivers unless u get the fix, and I've been to lazy to do that since my internet speed sux.
Anyone have an idea why I'm duplicated on there. Both IDs look exactly the same, same team of course, but the stats ID is different.
That happened after the database crash a few weeks ago. It's nothing to worry about.
Unfortunately, this has led me to only check the daily update page for my ID, but I won't use it for checking my standings anymore, because I can never tell if who I'm about to mow is real and who is a ghost from the database crash. The database has crashed before and was usually fixed quickly - but not this time. Hopefully it will be fixed soon so I can get back to using it for all my statwhore needs! :D But for now, I'm just using free-dc.org to check all my F@H threats...
