I've done tons of research on websites and searching the [H], and now I've managed to narrow down my choices.
Basic Idea of What I'm looking to do:
That being said, so far I've purchased a 77' Bonneville Heatercore. I plan to put it along with 2 120mm Panaflos, and a shroud, in the upper 2 5.25" drive bays. Air will be pulled off rad and out the top of the case.
I have heard lot's of good feedback about the TDX block for my CPU, and a Maze4 for my GPU. I'm open to any feedback on these, but I hear them repeated over and over.
Any reccomendations for the pump? I've heard good things about the D5 and DDC-12V pumps. Swiftec makes same ones, just rebranded, as well? I like the DDC-12V for it's size and noise, but I wouldn't want it if it hindered the performance too much.
Below is a picture of my case, with some MSPaint of what I thought would be the best routing.
That being said, here's a few questions and thoughts I currently have:
Well that's everything in my mind right now, let me know what you think would be the best picks.
Thanks,
Eric
- Watercool my 3700+ San Diego and 6800GT to yield a good overclock
- Keep total price range around $200-$250 if possible
- Quietest setup without sacraficing much performance
- Aesthetically pleasing, looking for big tubes and pump/rad out of sight
- Accellerator nozzels on the CPU? What do they do and should I bother?
- 1/2" OD, 1/2" ID, 3/8" ID? I've seen lots of sizes, and I like the look of big tubes but I don't want it to kink. Thinking 1/2" ID?
- Importance of fan shroud size? My calculations show if it's bigger than 3/4" I'll end up using part of the 3rd drive bay.
- Tygon or Clearflex, this has been beaten to death but I figured I'd throw it in there.
- Which pump should I go with? DDC-12V looks great, but is it strong enough for my loop?
- If not the DDC-12V, what pump should I use? If I use any other, I'll have to either mod or remove that floppy bay for it to fit, but I can manage that if needed.
- What is needed in the fluid, just distilled water and a cheap additive? I saw that MCT-5 stuff on the DD site for free with $100, should I even bother with it?
Thanks,
Eric
