firstbatch
- Mar 12, 2010
Finally purchased a new desktop computer after slaving away for far to long on a Pentium 4 machine.
Gateway DX 4831 with a i3-530 chip and 6GB RAM. Yep, Intel Grpahics card built in with 64MB dedicated memory. Not bad out of the box. Only a 300watt power supply and has a an available PCIe 16x slot.
Monitor is a Dell 2209wa. Want to go with dual monitors. Mostly web applications and not much gaming at this point.
Initally looked at a Quadro NVS 295 on ebay as it gets high marks but has DP and the Dell has DVI ...so I thought there may be a better card available that has DVI ports so I do not have to fool with the adaptors. Looked at some FX series cards but don't really understand the diffence in them all. I aslo, realize the 300W power supply is limiting. Bottom line would like to buy the best "used" card availble that will work with what is in this Gateway. Seems like some of the FX cards had a better spec and were cheaper than the NV.....but I'm green on the specs so.
Also, my second monitor will probably be an older 15" ViewSonic that only has VGA so should I be looking for a dual card with one DVI and one VGA or both DVI and and get a VGa adpator? Can you use 2 monitors togetther that are not of the same spec?
And do I need to get a multiple monitor software like UltraMon to be able to use a 2 monitor set-up?
Apreciate input. Great forum. Big help to me in selecting the 2209wa.
