Long time [H] Lurker here with a mighty conundrum on my hands right now that i can hope, someone can possibly help me resove, as i've spent about 30 hours of time in the past 4 days trying to get this sucker to work, and no luck
System specs are as followed
Barton 2800+ AMD processor
Asus A7N8X-la Motherboard
1GB Ram
160GB Maxtor 7200RPM Hard Drive
430w Antec Truepower Power Supply
SB Audigy2;
And my problem at the moment, My Radeon X850Pro AGP card
Basically, Anytime i load up a Graphical Application, or game, It'll run for anywhere between 1-5 minutes, My hard drive sounds like it studders, and my computer will hard lock on the screen that it was currently at about 10 seconds after the click, while looping about a 3 second clip of the sound it was playing.
So i think, defective/dying hard drive.
Load up a fresh copy of windows on another hard drive, as well as all the correct drivers and recent updates
Same Problem
Ok, so i load up a THIRD hard drive, and same problem.
Second and Third attempts were on a completely clean formatted windows install, with 2 diff versions of cata drivers, as well as omega drivers. Same problem with all 3
I've made sure my motherboard was updated. and all recent drivers were installed and running.
I can run windows in IE for days with the card in, and it will not lock up, but as soon as i load up a graphical program, its down in minutes.
My apologies if this was long and all over the place, as i have a hard time putting things into words where people can understand well, and i look forward to any help i can get to get this rig up and running, as running the integrated graphics is pure bleh right now :<
Thank you in advance for any help.
-Ron
1GB Ram
SB Audigy2;
Same Problem
-Ron
